Vent in Transmission/Differerntial? On Allis G.?
AWB
02-25-2008 16:53:22
I have found two threaded holes in the top of the transmission case, but they are threaded and don't go all the way through to form a vent. Isn't there supposed to be an air vent someplace? Thanks.
AWB
02-25-2008 19:45:31
 Re: Vent in Transmission/Differerntial? On Allis G.? in reply to AWB, 02-25-2008 16:53:22
Steve (ill) Thank you for the reply relating to the Allis G transmissison vents.
AWB
02-25-2008 19:43:38
Joe M (GA) Thank you for the info on the transmission vent.
Joe M(GA)
02-25-2008 18:59:33
Holds the headlight wire on the G
third party image
steve(ill)
02-25-2008 18:55:41
the transmission is used on teh B and C tractor also. there is a wire to the rear tail light from the llight switch that lays on the top of the trans case. there is a sheetmetal track that covers the wire and two small screws to attach... the transmission breaths thru the shift lever boot.
steve(ill)
02-25-2008 18:55:29
