d15 crank
pipe
02-25-2008 05:39:53
Does anyone know if a D12 or d14 crank well fit in a d15? Are the rods the same ? Thanks
Dick L
02-25-2008 06:49:36
 Re: d15 crank in reply to pipe, 02-25-2008 05:39:53
The crankshafts are the same. They take the same bearings they have the same stroke. They take the same front and rear seals. The flywheel bolt size and pattern is the same as well.
mlpankey
02-25-2008 13:36:48
 Re: d15 crank in reply to Dick L, 02-25-2008 06:49:36
thanks dick ihad to look at that again. diffferenc betwween a gas 149 and a gas 160 is .125 overbore. thne diesel has more stoke. memory not what it should be .
mlpankey
02-25-2008 06:12:28
if the d15 is a series 1 d14 stuff will work for they had 140 cubic inch identical motors. if its a series 2 it had a 160 and the only thing that will work is 160 stuff
