AC C
Jim Hunter
02-24-2008 11:53:19
Need to replace my release bearing again. Question is what is the difference between a pilot bearing and a throw out bearing? Looking at Valu-Bilt throw out bearing is double the price.
Steve in N.J.
03-01-2008 19:26:13
 Re: AC C in reply to Jim Hunter, 02-24-2008 11:53:19
The throw-out bearing is quite large and is pressed onto the bearing collar. And the bearing being quite large and a sealed unit is not cheap! If you've replaced the throw-out bearing more than once, you better inspect the pivot arms on each side. I've seen quite a few that are bent, and had to straighten them out a bit before re-installing a new bearing. We have the bearings in stock.
Steve@B&B
DARDAN
02-24-2008 22:28:11
You should be able to get that bronze pilot bearing at a bearing house for less than $5.
The throwout bearing interchanges with Ford 2-8N, Farmall A,B,C, Ford pickups before diaphram clutches, and others. Should be available cheaply localy without shipping cost. That must be one of the most popular throwout bearings ever.
Do you have 'free play' adjusted in the pedal rod?
Do you have a return spring on the clutch pedal?
Do you grease the throw out bearing rutinely?
Are the levers on the pressure plate adjusted evenly--so they all hit the bearing at the same point of travel.
Does anyone that operates the tractor have the habit of keeping their foot on the clutch pedal?
DARDAN
02-24-2008 22:24:06
old
02-24-2008 12:58:02
As JMS say and the throw out bearing is the one that hits the arms on the pressure plate and release the clutch so you can sift gears. Its a good idea to replace them both because if the pilot bearing is bad or worn it can/will take out a good number of other parts including the throw out bearing BTDT and learned the hard way after loosing a complete clutch, pressure plate and throw out bear because the pilot was bad
JMS/.MN
02-24-2008 12:10:29
Pilot bearing is the bearing inside the flywheel, clutch shaft fits into it.
