Changing motor on 1937 WC
tractorhank
02-24-2008 10:32:02
I have a 1937 WC with bad motor and have found a 1939 WC with good running motor. It has electric start and been converted to distributor. I want to keep my 37 looking correct. Will the 39 motor work with all the newer stuff removed and will it look correct. Hope someone with a little more Allis Chalmers knowledge can help. Thanks.
Peculiar Farmer
02-25-2008 10:05:26
 Re: Changing motor on 1937 WC in reply to tractorhank, 02-24-2008 10:32:02
I have a 37 that I bought from the original owner. After several years of cranking he took it back to the dealer and had electric start and a distributor installed. When you finish I'd bet they would look like twins.
Peculiar Farmer
Peculiar, MO
Michael Crowe
02-24-2008 17:47:35
Hank, the experts on the AC forum also say it will bolt right up. Michael
JMS/.MN
02-24-2008 11:39:40
They are 201 cu in engines- same block. You could switch flywheels just to keep it original, but there should be clearance for the ring gear if you leave the original flywheel on the 39. Use the magneto from the 37. If you wanted to keep the electric start you"d have to switch the clutch housing as well. Everything will bolt together.
