value of a CA..opinions needed..
Jesse
02-23-2008 18:01:07
Today as I out and about, I found a CA that seems to be about average with frame and rear weights, average rubber, and one hydraulic outlet. I don't see anything special about it, but then I usually deal with red tractors, but this one seems like something I might want. It has a 3 point, but the top link wasn't there. I was curious about something...what does this model usually run in average condition? I wasn't able to talk to the owner, but I was just wondered.
bob18
02-24-2008 14:53:30
 Re: value of a CA..opinions needed.. in reply to Jesse, 02-23-2008 18:01:07
bought mine around 6 years ago, came with sicle mower 6 ft disc, 2 bottom plow, homemade spring tooth and post hole digger, a nice 2 can planter with fertilizer cans. good paint and had been treated well as so far i have nothing to it other than maintenance and a new tire (i ruined the good one). the best 3200 i spent! work it every year plus parades
dakota dave
02-24-2008 03:50:17
All the running CA 's I've seen were between 2500 to 3500. That was without wieghts. They are a good little tractor.
steve(ill)
02-23-2008 20:10:44
depends on where you are i guess. in the mid west, i think you can find a decent CA for $1500. I think $2000. is high dollar.
Beans
02-23-2008 18:57:46
All the Ca's i've seen are usually running anywhere from Two to Three Thousand dollars.
steve(ill)
02-23-2008 20:13:16
 Re: value of a CA..opinions needed.. in reply to Beans, 02-23-2008 18:57:46
http://www.tractorshed.com/cgi-bin/photoads/classifieds.cgi?search_and_display_db_button=on&db_id=204560&query=retrieval
1755
02-26-2008 18:09:33
 Re: value of a CA..opinions needed.. in reply to steve(ill), 02-23-2008 20:13:16
we have 2 CAs and we use them for mowing one has a woods L306 and the other has the same thing exept it is 3pt insted of a belly mower and with the hand clutch they are a good match for mowing the pastur and barn lot that there are no cows on
