WD rear main seal, (engine)
Rock_Picker(MO)
02-20-2008 14:59:06
I need to replace the rear main seal on my WD (1953). Can I buy just the seal? Or can I just get some material and make one? Suggestions would be appreciated..... ..tx....RP
alliswd45
02-20-2008 17:29:11
 Re: WD rear main seal, (engine) in reply to Rock_Picker(MO), 02-20-2008 14:59:06
You should be able to just by the main seal, but it might come with some other gaskets
DARDAN
02-20-2008 16:28:15
It might be good to 'plastigage' the rear main bearing to be sure the reason for leakage is not loose bearings allowing the crank to flop around.
That engine has a rope type seal that has little forgiveness for slop in the bearings.
A small wedge driven gently under the flywheel, at the bottom, will crowd the crank up against the top bearing to get an accurate 'plastigageing' of the bearing clearance.
DARDAN
02-20-2008 16:27:27
