fuel lever on won't move--govenor problem
Michael E. Dzia
02-20-2008 04:43:43
I cannot give my engine any gas, runs at slow speed only. Seems like the throttle lever is stuck and at the govenor it seems unmoveable. I cannot give it any adjustment to speed up the engine.
Gene
03-09-2008 20:48:32
 Re: fuel lever on won't move--govenor problem in reply to Michael E. Dziadosz, 02-20-2008 04:43:43
Disconnect the rod going from lever to the govenor - at the govenor. Try moving the throttle at the operators platform. If the lever moves - then a govenor problem. If the lever doesn't move then the problem is in the linkage.
Like the others have stated. It really would help to know what make and model tractor you have.
Michael E. Dziadosz
03-09-2008 21:02:09
 Re: fuel lever on won't move--govenor problem in reply to Gene, 03-09-2008 20:48:32
Thank you for your time and civility. I mentioned on my second try, that it was a D-17 gas motor. The govenor is stuck. The govenor has the distributor built into the housing. Thank you again. Mike
Michael E. Dziadosz
03-09-2008 20:34:32
I failed to mention it was a D-17 gas engine.
old
02-20-2008 07:54:46
Need more info to help you. What model tractor is it since the linkage on them are different depending on the model
Dick L
02-20-2008 09:11:24
 Re: fuel lever on won't move--govenor problem in reply to old, 02-20-2008 07:54:46
He talks like me. I tell people that if they knew what I was thinking they would have no problem with what I was saying. (:^D
Michael E. Dziadosz
03-09-2008 20:38:11
 Re: fuel lever on won't move--govenor problem in reply to Dick L, 02-20-2008 09:11:24
with out mental reservation, I commend your reply and the level of mental duress you put your simple mind through, in obtaining a purely factual response.
old
02-20-2008 11:46:36
Yep can be very hard to read a persons mind in person let alone over the net. LOL
