wd brake pin
marluseb
02-17-2008 06:59:00
How is the best way to get the pin out of the bottom of the brakes? The one that goes through the housings.
JMS/.MN
02-17-2008 10:23:24
 Re: wd brake pin in reply to marluseb, 02-17-2008 06:59:00
Drill a 3/4 inch hole in a foot long flat iron. Slip it over the pin,and weld it in place. Makes a good handle to twist the pin, heat of welding helps loosen it as well, sturdy enough to hammer on. Grind off the weld and re-use the pin. Install with never-seize. Lots simpler than trying to drill it out, or drill and tap for a slide hammer.
Texas Denny
02-17-2008 10:20:06
I remove the rear wheel and support the entire axel with an engine hoist. Then I loosen the very large nuts that hold the rear axle to the differential case. When the axle moves with respect to the differential, this pin must move. Once it is broken loose, it can be removed. I've tried various other methods involving tapping and welding and pullers - all of which failed. This one can't fail.
marluseb
02-17-2008 11:52:56
 Re: wd brake pin in reply to Texas Denny, 02-17-2008 10:20:06
We tried this method and it broke it loose on the outside housing so we put the keeper piece on and tried it but it just wants to roll the lip off of the pin.
Texas Denny
02-17-2008 14:07:59
 Re: wd brake pin in reply to marluseb, 02-17-2008 11:52:56
I'd pull the axle then as it seems to be stuck to the axle. Once the axle is off, shouldn't be too hard to break it loose. I pulled the lip off on my D-17 but still got it out this way.
Texas Denny
02-17-2008 10:22:44
Also, watch for binding on the shaft. May need to adjust the screws and put a crowbar or large screwdriver in there to separate these castings. My record with this method is 2-0. With the others, it is 0-4.
