Allis model C
Tom in Wisconsi
02-16-2008 11:40:15
I'm haviing trouble with my C, it runs ok when it's cold but when it warms up it and you start working it, it wants to die, it won't even pull itself let alone push snow or pull firewood. I just had the magneto looked at and the condenser changed and that didn't help. I was wondering if anyone had an idea what my problem might be.
DARDAN
02-19-2008 00:57:35
 Re: Allis model C in reply to Tom in Wisconsin, 02-16-2008 11:40:15
Don't know if this relevant to your problem, but my WD was doing the same thing to me and sounding like it had a irratic miss when warmed up and particularly under load.
After much tuning and checking (fuel and ignition), I found that the valves were sticking! The valves were so gummed up that I had drive them out with a punch. They looked like they had been assembledd with TAR. A good cleaning and a light valve job and it runs and pulls like new again.
old
02-16-2008 12:03:29
answer a few question first. Does it run better if you choke it?? If it does then you have a fuel problem. Try doing this. Pull the drain plug from the bottom of the carb and make sure you have a good steady flow of gas. If you do then pull the main jet cap since your carb should not have an adjustable main jet. Make sure you have a good steady flow of gas out the main jet area. If you don't then you have a clogged up carb. Now if its not the carb then your timing could be off or the rotor may be one tooth off in the mag and that would also cause your problem. If you need info on the mag send me an e-mail and I'll send you a manual for the mag which will help you trouble shoot your problems
