AC 190XT starts but wont move
David Mitchell
02-12-2008 11:17:42
What would cause an AC 190-XT gears not to engage in cold weather?I can crank it and it runs fine .Now we have an ice storm ,I put it in gear and it moves about 6 inches and stops.It is 20 degrees now but any other time at same temp it does fine. Can any one give any ideas?
ben up north
02-13-2008 13:03:25
 Re: AC 190XT starts but wont move in reply to David Mitchell, 02-12-2008 11:17:42
Could aslo have bad brakes...i know they arnt quite the same, but we just had a 175 allis do the exact same thing....it would move about 6" back and forth and then lock up the tire. just my $0.02
Joe(TX)
02-13-2008 04:51:38
Its probably the POWER DIRECTOR. It is on the steering cicuit. Does the steering work ok? You may not be getting hydraulic pressure.
old
02-12-2008 12:10:50
You might have some ice/water in the power divider which if you do would keep it from moving.
David Mitchell
02-12-2008 12:14:10
 Re: AC 190XT starts but wont move in reply to old, 02-12-2008 12:10:50
What is the power divider?
old
02-12-2008 12:22:57
 Re: AC 190XT starts but wont move in reply to David Mitchell, 02-12-2008 12:14:10
Also called the high low shifter on the right fender. It works by way of hyd pressure and if it has water/ice in it you could be have a hyd. pressure problem
