power steering
D17JIM
02-11-2008 06:55:24
My D17 series II has a power steering oil leak. I seems to be coming from the breather in front of the radiator. I have not had anyone turn the steering wheel to look for the leak. Its leaked down past the gear or fill point and still leaks. I have always filled it just to the top of the gear you can see in the fill hole. The cap is always wet after running. Thanks Jim
old
02-11-2008 07:52:16
 Re: power steering in reply to D17JIM, 02-11-2008 06:55:24
Warning this is just an educated guess so I may be off on this. Most system like that have a vent and if it gets clogged it will cause a problem like what you have. But as I said this is just a guess and I would have to go out and look at my D-17 to be 100% sure if there is in fact a vent and sorry with the weather like it is I'll not be doing that looking at this time LOL
D17JIM
02-11-2008 10:43:58
 Re: power steering in reply to old, 02-11-2008 07:52:16
Thanks Old. It does have a vent or at least I'm pretty sure it does. I'll check it out, but the vent is where the oil seems to be coming out. I'll check it tonight. Jim
JMS/.MN
02-11-2008 18:25:18
 Re: power steering in reply to D17JIM, 02-11-2008 10:43:58
On my Series III, the vent is part of the filler cap- inch in diameter, about 3 inches tall, located behind the grille.
old
02-11-2008 10:51:16
What happens is the oil gets hot and expands some and that pressure building up then cause the vent when it does let something out to sort of spray the hot oil instead of just venting off the air pressure which is what should happen
D17JIM
02-12-2008 04:41:19
 Re: power steering in reply to old, 02-11-2008 10:51:16
Got home last night and had to go to town to pick up supplies for the bathroom remodeling (wife highly suggested I do that) so I will check the vent asap and let you guys know what I find. Thanks Jim
