WC allis Chalmers , Oil Filter,
Mark Nicholson
02-10-2008 15:30:34
I need a oil filter for a WC unstyled that takes a element filter that goes in a canaster The old measures 8 by 4 1/4 anybody got a part no. or where I can get one , Thanks for any help
Obsession
03-12-2008 19:21:16
 Re: WC allis Chalmers , Oil Filter, in reply to Mark Nicholson, 02-10-2008 15:30:34
Try Napa or car quest
Gene
02-12-2008 09:32:28
Checked both my WC (1936 unstyled) and WD this morning. The oil filter on both is Hastings LF405.
The Hastings LF405, or comparable filter, fits the glass jar oil filter base.
Jack a
02-12-2008 14:30:24
 Re: WC allis Chalmers , Oil Filter, in reply to Gene, 02-12-2008 09:32:28
The very early WC had a canister style. Yours is a spin on type if I read your description right. I believe he is talking about the other type. Like what is on an old M Farmall.
Jack a
02-12-2008 05:57:55
Gene and Jim are on the wrong track. Most Case dealers have a Fleet Guard filter book with measurements listed for each available Fleet Guard filter. Might take some time thumbing through book. They may have an old catalog they would give you.
Jim E NEIN
02-11-2008 19:06:33
Fram C159 usually at TSC/Rural King/Farm Fleet. Unless you get one from the dealer but I forget their part #. Both are about the same price. The farm stores normally run out of stock late winter/early spring as most people change their oil in the spring.
Gene
02-11-2008 18:41:04
I get them from the autoparts store. The same filter for the WC fits the WD. Next time I'm out to the shop I will get the numbers off the side of one.
AGCO should have them on hand. Probably a bit more expensive than from the autoparts store. Your local farm and ranch supply store or tractor supply.
