C-II Bull Gears
Kentb of SWMO
02-09-2008 18:25:04
Anyone out there know the gear ratio of the C-II Bull Gears. I have a project in mind where I need a 4 to 1 HEAVY DUTY gear box. I also have a few C-II parts machines.
Kent
Kentb of SWMO
02-10-2008 18:06:13
 Re: C-II Bull Gears in reply to Kentb of SWMO, 02-09-2008 18:25:04
i know I could do it that way but the parts machins are at Dad's and I thought someont would know of the top of their heads.
Kent
JMS/.MN
02-10-2008 11:32:42
If you already have the C-II, disconnect the drive coupler between the transmission and gearbox, and rotate the axle one revolution, while counting how many turns the input shaft makes. Can do it with the wheel jacked up from the ground, or if removed, use a lever to turn the axle with wheel bolts installed.
