Exhaust ports on WD45 Head
doorman
02-08-2008 22:01:16
The exhaust ports on the head of my WD45 are all pitted from a previous exhaust leak. Is there a filler I can use to seal this area that will withstand the heat? I want to make sure I don't have any leaks when I put it together.Thanks for any help, doorman
Obsession
03-12-2008 19:28:41
 Re: Exhaust ports on WD45 Head in reply to doorman, 02-08-2008 22:01:16
Plane the head or replace it. Have a good machinist check the manifold and head for you. A WC, WD, 45, 17, 170, 175, or E combine gas head will fit. Older heads require studs and differnt valve cover. Newer D17 and up use long reach spark plugs. The heads are easy to find used.
DARDAN
02-12-2008 23:27:18
I have been using Hi-temp red rtv on exaust manifold to head for years, and never had a failure. Just as long as the surfaces are free from loose stuff and are dry. Even been able to reuse the AC exaust rings in a pinch.
doorman
02-12-2008 17:45:47
Thanks for the suggestions. I have decided to try the high temp silicone. Thanks doorman
Larry Condon
02-10-2008 07:36:00
I have a 56 International truck that the exhaust manifold was leaking at one port after installing a new gasket. I mixed up some JB Weld and packed it in and it has held great.
Larry
Jeff Z.
02-10-2008 05:59:56
You may be able to fill the pits with this.
http://www.amazon.com/gp/product/B000E4HWLW/ref=cm_cr_pr_product_top/102-5010894-5436936
mlpankey
02-09-2008 17:32:23
i have a head on my pulling tractor that water was comming into the exhaust port .i used a product that is used in the nuke industry to keep high pressure steam from cutting through valve seats. the product is belzona 111 supermetal . the exhaust port has done fine for 0ne year so far with this product.
Maark
02-09-2008 11:01:29
I guess you could use HI-Temp Silicone RTV sealer.
