D15 - Parts Diagram for 3 PH
MapleStone
02-07-2008 17:39:26
Would anybody happen to have a digital copy of the parts diagram for the 3 PH of a D15 series II?
My Dad has a D15 and needs some replacement parts but his has been cobbled up so bad that we wonder if it's all original or not.
Does anybody know if AGCO still carries the parts for the 3 PH?
Thanks
Dwight in Orlando
02-08-2008 17:36:43
 Re: D15 - Parts Diagram for 3 PH in reply to MapleStone, 02-07-2008 17:39:26
You can get the crank w/threads, the lower fork and trnyon. From A& I .You can see them and the prices on line. Go to OK tractor Jim DanForth for the link. Dwight in Orlando
BrianAhart(MO)
02-08-2008 10:05:03
Many of the 3PH parts are common between the D10/12/15 tractors (i.e. crank, clevis, trunnion, and others). The crank and clevis are available on the aftermarket from A&I and are virtually identical to the original components. Drop me an e-mail if you need more details.
LilFarmer
02-08-2008 07:54:06
Do you have a fax number? I can fax you all the three point hitch info, including part numbers.
Paul
MapleStone
02-08-2008 10:47:40
 Re: D15 - Parts Diagram for 3 PH in reply to LilFarmer, 02-08-2008 07:54:06
Yep
Fax (905) 443-0986
Attn Trevor
LilFarmer
02-08-2008 12:00:09
 Re: D15 - Parts Diagram for 3 PH in reply to MapleStone, 02-08-2008 10:47:40
On the way at 3:10 ET.
Need any more, just holler.
Paul
MapleStone
02-08-2008 12:05:04
 Re: D15 - Parts Diagram for 3 PH in reply to LilFarmer, 02-08-2008 12:00:09
Got it! Thanks alot!
Talk to you soon.
MapleStone
02-07-2008 18:29:04
Should have added that even a good picture of a factory 3 ph would help.
Thanks
