70 Gas govenor problem
Josh Keister
02-06-2008 18:09:49
We have been having trouble lately with our 170 gas. If you tap the throttle, the rpm's go way up. Its as if the govenor now only has two possitions. All or nothing. We replaced the carb early last year, and it ran fine all summer. Just in the past few weeks it has started this. What should I be looking for. Thanks guys.
mlpankey
02-07-2008 15:28:12
 Re: 70 Gas govenor problem in reply to Josh Keister, 02-06-2008 18:09:49
id beat the weights broke. i wouldnt run it until i knew for sure . broken weights are a good way to ruin a cam gear.
Jack a
02-12-2008 06:08:56
 Re: 70 Gas govenor problem in reply to mlpankey, 02-07-2008 15:28:12
I bet you're right. After I thought about it.
mlpankey
02-08-2008 14:37:38
no you can buy new weights and pins that hold them in place.
Josh Keister
02-07-2008 18:32:01
 Re: 170 Gas govenor problem in reply to mlpankey, 02-07-2008 15:28:12
Does a broken weight require a new govenor assembly? I intend on tearing into it on Saturday.
Jack a
02-07-2008 03:37:12
Threw weights maybe or broken spring. I bet it's a spring.
Josh Keister
02-07-2008 10:54:10
 Re: 70 Gas govenor problem in reply to Jack a, 02-07-2008 03:37:12
Are they accessable on the right side of the tractor, or do you need to take the hood panels off and come in from the front at the fan?
Jack a
02-07-2008 12:34:43
 Re: 70 Gas govenor problem in reply to Josh Keister, 02-07-2008 10:54:10
Don"t have a 170 in front of me but on a D17 you can access without removing sheet metal.
Josh Keister
02-07-2008 12:44:42
 Re: 70 Gas govenor problem in reply to Jack a, 02-07-2008 12:34:43
Thanks Jack. I will look into this on the weekend.
Josh Keister
02-06-2008 18:12:52
 Re: 170 Gas govenor problem in reply to Josh Keister, 02-06-2008 18:09:49
i meant 170
