Scraper Blade
Texas Denny
02-02-2008 12:55:17
With my D-17, I've got an Allis Chalmers 6 foot blade with three adjustments. Everything is dandy on two of these adjustments. The adjustment for blade tilt (forward and backward from the top of the blade) is adjusted with two large screws. I now have these adjusting screws adjusting like they should. At the end of the screw, it has a hole for some kind of a shear pin. All that will go in this hole is about a 16 penny nail (actually a little smaller than that). These nails shear very easily. I don't know what Allis used for these small pins. If I drop in nails, I can't adjust the screws. And the nails are too soft. I thought I'd just hog it out a bit for a little larger nail but, I discovered that there is a hardened insert in there (ruined my end mill before I realized it).
So I need to know what this is supposed to look like. Maybe that Hardened insert is the shear pin and it has be sheared.
Thanks,
skyharborcowboy
02-04-2008 14:57:10
 Re: Scraper Blade in reply to JMS/.MN, 02-02-2008 12:55:17
Texas Denny said: (quoted from post at 16:01:41 02/04/08) I've been doing that for the last ten years. I can rarely even complete one job without the pins shearing. I've got to make it three to four times stronger than that tiny pin.
Thanks,
Why not look through a McMaster Carr catalog online and see if you can find an actual shear pin in the diameter you require instead of trying to engineer your own shear pin out of something.
Joe
wilman
02-03-2008 16:28:58
 Re: Scraper Blade in reply to Texas Denny, 02-02-2008 12:55:17
Denny,
This is what it should look like on the adjustments toward the blade.
third party image
The castel nut is serrated or like lovethisallis says, it looks like a castle. It should have a cotter pin thru it to hold the nut in place.
Hope this helps.
Wil
Texas Denny
02-04-2008 06:49:37
 Re: Scraper Blade in reply to wilman, 02-03-2008 16:28:58
Ok. This makes sense. But it is not what I have. There are no threads on the end of the screw. All that it has is the hole for the cotter pin. This screw has never had threads as it is the right diameter to go though the trunion on the blade. I could try cutting threads on it.
I know what a castalgated nut is. Would be dandy if these lead screws were set up like your picture.
Thanks for the picture. It answers my question and then some. I'll try and cut threads. As I recall the screw end is about 1/2" so I would try to cut 1/2-20 and pick up a couple of castalagated nuts.
Thanks,
wilman
02-04-2008 07:45:08
 Re: Scraper Blade in reply to Texas Denny, 02-04-2008 06:49:37
Instead of cutting threads on what you have, can you just put some washers or slip a nut over the end and use a cotter pin to hold them in place. The main purpose of that nut on the end is to hold the trunion in place. There are no threads that go thru the trunion. Here is a picture of the complete assembly.
Wil
third party image
Texas Denny
02-04-2008 13:01:41
 Re: Scraper Blade in reply to wilman, 02-04-2008 07:45:08
Thanks,
wilman
02-05-2008 16:37:24
 Re: Scraper Blade in reply to Texas Denny, 02-04-2008 13:01:41
Now that you say that, it makes sense that you would have problems doing what I suggested. A good blacksmith shop maybe able to help you out and make those for you. Good luck.
Wil
John NwMo
02-03-2008 13:02:34
A castellated nut is one that has slots to put a pin thru to heep it from turning. I suspect some one has used a roll pin in yours since it would not drill out. As I remember the nuts should be 3/4 inch coarse thread and I used roll pins in the last one I worked on since they could be short enough to not interfear with turning the screws. John
wilman
02-02-2008 16:41:40
Which end of the adjustment are you talking about?
The inside next to the blade should have a castel nut on it with a cotter pin in it that holds a bracket on that the adjustment screw turns thru and that bracket is attached to the blade and is what holds the blade at the adjusted angle. The outside of the adjustment should have a crimped pin that is used to turn the adjustments.
Hope this helps.
Wil
Texas Denny
02-02-2008 18:59:23
 Re: Scraper Blade in reply to wilman, 02-02-2008 16:41:40
I am talking about the end toward the blade. I'm not familiar with castel nuts. It is tough to describe. Maybe I could take a picture and email it to you.
loveshisallis
02-03-2008 14:13:55
 Re: Scraper Blade in reply to Texas Denny, 02-02-2008 18:59:23
On my oxnard blade it has cotter pin in the castle nut, closest to the blade. The name "castle" nut got its name as it has "Serrations" on it, just like the towers of a castle.
