pto for 38 AC WF
steve in mtavil
01-31-2008 16:02:34
Can anybody tell me how to engage the pto on this model? WF
Joe M(GA)
01-31-2008 16:18:01
 Re: pto for 38 AC WF in reply to steve in mtaville ca, 01-31-2008 16:02:34
Steve, look under the tractor at the PTO drop box, you should see a rod coming up and to the rear with a knob on it.This drawing is for the WC but the idea is the same. Pull to run pto
third party image
01-31-2008 16:29:40
 Re: pto for 38 AC WF in reply to Joe M(GA), 01-31-2008 16:18:01
I'm sorry, I mean for the belt pulley, can you tell me Joe
JMS/.MN
01-31-2008 16:48:45
 Re: pto for 38 AC WF in reply to steve in mtaville ca, 01-31-2008 16:29:40
Same as on the WC, WD, WD45. Above the pulley housing is a setscrew with a locknut. ENGINE OFF!! Loosen the nut and screw, slide the pulley assembly into the tractor a couple of inches, until the gears engage. Tighten setscrew- there are tapered holes in the pulley sleeve for this. Those tapered holes are not in alignment- find one that gives you about a 1/8 to 1/4 inch backlash on the face of the pulley when you rotate it back and forth. If still original, the dealer should have punchmarked the proper hole which gives correct backlash. Do not do this with the engine running unless you have the foot clutch locked down- since the gear you are engaging to is turning when the engine is running.
01-31-2008 17:27:25
 Re: pto for 38 AC WF in reply to JMS/.MN, 01-31-2008 16:48:45
Dear Joe, Thank you so much sir, you made my day
Joe M(GA)
01-31-2008 16:45:17
see if this helps - third party image
third party image
