D-15 steering
Jrry
01-31-2008 06:22:42
I need to disconnect the steering rod from the front power steering box. This is a Series One with wide front tractor. I do not find a point of disconnect. Is there a joint that comes apart on the steering rod? I thought it would disconnect at the universal joint but do not see a way to do it? thanks in advance for any help. Jerry
Gatz
01-31-2008 16:20:41
 Re: D-15 steering in reply to Jrry, 01-31-2008 06:22:42
There should be either a splined coupling on the PS input shaft that the star-shaped end of the horizontal shaft enters into right where the PS valve is..
OR
The horizontal shaft may have a big end with the input shaft to the PS valve pinned to it.
If it has the star-shaped end, it should just slip out when you take the PS assembly off.
If a pin, you need to "buck" the shaft/coupling so as not to damage it when removing the pin.
