model differences
JayT
01-27-2008 19:32:51
what are the differences between a WC and a WD. how can they be told apart at a glance.
John (C-IL)
01-28-2008 13:34:48
 Re: model differences in reply to JayT, 01-27-2008 19:32:51
From the truck at 60 MPH look for the throttle and hydraulic lever quadrant behind the steering wheel, it's a dead giveaway and only seen on the WD and WD45.
Brian G. NY
01-29-2008 11:19:08
 Re: model differences in reply to John (C-IL), 01-28-2008 13:34:48
John, I like that, 'cause I've actually done that many times. My interest is in the WD/WD-45s so this method can save a lot of time. LOL
JMS/.MN
01-29-2008 14:15:04
 Re: model differences in reply to Brian G. NY, 01-29-2008 11:19:08
Plus the Power-shift rear wheels and the shift lever---compared to the WC. Very visual indicator from a distance.
Ted In NE OH
01-28-2008 08:48:05
WD has hand clutch, spin out rear wheels, SN located on left brake housing,abd foot brakes. The WC has hand brakes, non-adjustable rear wheels, no hand clutch, and serial number located on pumpkin of differential.
JMS/.MN
01-28-2008 07:56:14
Major differences ate that the WD had live pto and hydraulics- WC had neither, along with the capacity for mounted plows and other tillage equipment. Foot brakes were an improvement, also a bit more power from the same basic engine.
old
01-27-2008 19:38:05
WC will have hand brakes. Also the transmission is bolted to the bell houseing instead of being close to the rear end. The shifter will also be a lot longer on the WC then on the WD
