WC Steering
Don Ober
01-26-2008 07:12:35
My WC for some reason got water in the steering box and frooze didn`t hurt the box but can`t steer it unless I thaw it out ,I have owned this tractor for 14 years and this is the firt time this has happened .Is there any way too drain the pedalstal wih out dismantling it,it has a wide front I belive it is a Schwartz in anycase it is aftermarket put on when Mr. Sell bought it new in 47. THANKS, Don
Don Ober
01-26-2008 15:54:59
 Re: WC Steering in reply to Don Ober, 01-26-2008 07:12:35
I allready know that,is there a drain on the pedalstal? Or will I have to dismantle front end to drain.I might try shop-vac and suckion tube ?
NE IA
01-26-2008 07:36:11
Oil is not frooze, water in oil is. Warm and drain milky oil and repalce. Probably all gear boxes are the same way, not uncomon. If they set for along time in warm weather you can crack a drain plug and let water drip out. This must be done before starting tractor or moving it as you will remix the water with the oil. Water will always seperate and go to the bottom.
