Mag reassembly
loveshisallis
01-25-2008 14:49:22
I have a FM mag for a B with no spark and I am going to open it up to check the points , to see what I can do. Is there a trick to realign the gears up so that the mag is still timed correctly?
I have not openned one up yet, and could use the help.
Pappy
01-25-2008 23:55:37
 Re: Mag reassembly in reply to loveshisallis, 01-25-2008 14:49:22
Rod(NH) posted some wonderful instructions on this magneto. Do a search on his postings.
TexMac
01-25-2008 21:35:31
Duey's web page was what I had. I just could not track the links back. That pdf that Clay linked to should have any other info needed. Thanks, I saved a copy too.
Duey (IA)
01-25-2008 18:13:20
I have some pictures and tips on my web site.
old
01-25-2008 16:30:49
Send me an e-mail and I'll send you a manual for that mag. I have on on my computer
loveshisallis
01-26-2008 11:12:50
 Re: Mag reassembly in reply to old, 01-25-2008 16:30:49
Hi Old;
I woul;d appreciate the manual on the FM mag and I thank you.
By the way in your other post on my model B and your recommendation of putting trans fluid in the oil , in the gas. Can a guy use this rather than tearing down the engine. I am curious about what you think
thank You
old
01-26-2008 14:29:20
 Re: Mag reassembly in reply to loveshisallis, 01-26-2008 11:12:50
All the ATF does in the gas and oil is cleans things up and loosens up sticking valves and ring. If the engine is still good it help but it does not fix a worn out engine. As far as the manual you have to send me and e-mail so I can send it to you. I can't send it any other way
Clay in MI
01-25-2008 16:03:16
This might be what TexMac mentioned.
TexMac
01-25-2008 15:50:55
I just filed and reset the gap on my points and it worked well after being idle for several years. There is a manual for the FMJ mag somewhere on the net. Someone on here posted it. I will try to locate the source of the copy I downloaded if you cannot find it.
