AC 185 Hydraulic
Tim99
01-25-2008 11:16:07
I am troubleshooting a hydraulic problem on AC 185. The remotes will not lift an implement nor will the 3pt rams lift any weight. Without a load, the 3pt will raise but the lift control lever does not return to neutral when raised. My understanding is that it has a 2 stage hyd pump, with 2nd stage being for power steering. Steering is fine, not even sluggish. My first thought is it is the pump, but also wondering if it could be in the valve complex since the power steering showing no sign of problem. Can anyone provide suggestion on identifying where the problem is?
