Pullin Distributar
alliswd45
01-24-2008 18:35:55
Looking for a good high performance pulling distributar for a D17 engine.
mlpankey
01-25-2008 12:25:50
 Re: Pullin Distributar in reply to alliswd45, 01-24-2008 18:35:55
yeap use the petronix pick up in delco distributor with msd box and blaster 2 coil.
John T
01-25-2008 09:03:34
Do you have a good stock distributor already??? If so I would just buy a Pertronix Electronic Ignition switch which installs directly in the distributor replacing the old points n condensor and then buy the matching Pertronix High Energy High Voltage Coil (Flame Thrower I believe???) and run a wider plug gap for a hot wide high energy spark. Use good quality plug wires if youre running at firing higher voltages..... ..
John T
alliswd45
01-25-2008 14:40:22
 Re: Pullin Distributar in reply to John T, 01-25-2008 09:03:34
Can I still use the swith to shut off and trun on the ignition.
mlpankey
01-25-2008 15:24:02
 Re: Pullin Distributar in reply to alliswd45, 01-25-2008 14:40:22
yeap either the petronix by itself or with the msd box have designated switch wires.
