WC/WD part diagrams
Mathias NY
01-22-2008 13:15:21
Does anyone know if there is a good online place to see a parts diagram for the hand clutch on a WC/WD? or have a picture that they could email me? I am trying to understand how the mechanism works. Thanks for the help.
Kentb of SWMO
01-23-2008 07:02:53
 Re: WC/WD part diagrams in reply to Mathias NY, 01-22-2008 13:15:21
WD, WD-45 did not use an axle clutch. The hand clutch on them is in front od the transmission. The CA is the Allis that used an axle clutch.
Kent
mlpankey
01-22-2008 18:00:48
yeap hes correct wc didnt have a trans clutch. ac 11 manual page 51 paragraph 179 is where the .030 on the pressureplate to clutch disk came from. dont know how wc blew by me but it did.
Mathias NY
01-22-2008 20:08:32
 Re: WC/WD part diagrams in reply to mlpankey, 01-22-2008 18:00:48
Thanks for the replies. I'm not really an AC guy, but was wondering what type of clutch is used on the axles of the WD. I have been kicking around the idea of turning a Case 'D' into a crawler, but was stuck on the idea of how to build in steering clutches. If the AC axle clutch design was straight forward I might be able to incorportate one that into the axle housing, since I would have to fabricate them anyway. I probably won't get past the drawing board with the project, but I still like to dream...
JMS/.MN
01-22-2008 21:21:10
 Re: WC/WD part diagrams in reply to Mathias NY, 01-22-2008 20:08:32
Never anything wrong with dreaming. WD does not have an axle clutch, but does have an oil clutch, hand operated, in front of the transmission, which gives the tractor live pto and hydraulic- not independent, and too many people don"t know the difference between the two. Oil based steering clutches on crawlers are a more recent development- earlier ones were dry. Oil based last longer.
JMS/.MN
01-22-2008 16:48:11
WC does not have a hand clutch, WD, WD45 do. Covered in I&T AC-11 manual. Hand lever is a simple snap over center design, holding the plates together to engage. Three sets of brass shims on the mechanism, add or subject shims to get the right snap.
mlpankey
01-22-2008 14:22:15
it shop manual from youre local tractor supply. check the clearance with clutch ingaged between pressure plate and re disc. desired clearance isa .030. obtianed by removing or adding shims . shims are between the two halves are bolted together.
