WC Allis steering
J W
01-21-2008 15:05:30
We have more "play" in the steering worm in a WC than we would like to have. Is there a way to take some of it out?
Bill(Wis)
01-21-2008 19:29:58
 Re: WC Allis steering in reply to J W, 01-21-2008 15:05:30
A common problem. There is a large set screw on the front of the tower between the front wheels that is used to snug up the key at the bottom end of the vertical shaft. More than likely, the key has become worn (fancy that after 70+/- years) and will have to be replaced. It's quite simple, just remove one front wheel so you can get to the cap screw on the bottom of the front axle. It's all self explanatory once you see how it's put together.
Kevin LA-CA
01-21-2008 19:26:55
Two other things to look at. Behind the flange that mounts the backside of the shaft that enters the front casting there are some shims. Pull on the shaft to see end play. Jamb nut on front of axle also adjusts some play.
Otherwise JMS has the key sloppy places - steering knuckle and knuckle pins.
JMS/.MN
01-21-2008 15:21:40
If you"re talking about the wheels wiggling while going down a road- especially a blacktop road vs. gravel- the slop may be in the bearing at the base of the steering pedestal. Never really turns, but gets "hammered" with every side to side hit going down the field. Gets scalloped over time. Other slop points are worn pins in the steering driveline, and the knuckle itself. Each wear point adds up to sloppy steering. Really no adjustment in the steering sector (casting) itself.
J W
01-21-2008 19:27:16
 Re: WC Allis steering in reply to JMS/.MN, 01-21-2008 15:21:40
Thanks. The bottom end seems good. No play down there. But considerable play between the worm and the gear. Wondering what type of bearing or bushing is under the gear? If the tooth contact could be tightened up most of the loose steering would disappear
