Question on engine stand
loveshisallis
01-21-2008 13:00:16
Does anybody ou tthere know where a guy can get a engine stand, one made in the U.S. of A.?
I am looking all over and no luck.
DARDAN
01-23-2008 23:15:22
 Re: Question on engine stand in reply to loveshisallis, 01-21-2008 13:00:16
If you have access to welding E stands are easy to make. Round pipe, square tube, or 2 pieces of channel leg to leg to make a box. My major complant with the commercial ones,(other than origin), is the foot print is too small and thus poor stability. That and 1/8 wall tube has marginal strength.
When I build them, I go with at least 3" x 3/16 wall tube and a 4ft x 4ft footprint. A little cumbersom, but not as cumbersom as having it falling over when you roll the engine.
jk
01-22-2008 12:26:49
i have an egine stand i made out of 4 inch channel iron. it has a gear redution gear box on it, and a lovejoy coupler so i can turn the engine (on stand) with my drill, to work on the bottom of the motor. its not forsale but i will send you some pics if you'd like. it was orginally made to support an F-12 engine, and i've had a small block ford v8 on it with no problem.
D13
01-21-2008 14:56:40
Bought a Delco, was maid in China, had to file off weld slag to assemble. Buy a cheap one at C-S-K, Murrays, or wherever is handy. Haven't found a USA made one in a long time.
R Aiken
01-21-2008 14:46:38
Try again
,third party image
John (C-IL)
01-22-2008 07:31:48
 Re: Question on engine stand in reply to R Aiken, 01-21-2008 14:46:38
Dand Richard, that's a dandy!
R Aiken
01-21-2008 14:39:53
Do you want this?
loveshisallis
01-22-2008 10:42:56
 Re: Question on engine stand in reply to R Aiken, 01-21-2008 14:39:53
R aiken;
Are you asking if I want to buy it, if so what are you looking to get?
It's made here ...right?
JMS/.MN
01-21-2008 13:21:23
Not hard to make one with some 3-4 inch pipe, flat stock, caster wheels, etc. Just google for some design ideas.
856 puller
01-22-2008 09:40:13
 Re: Question on engine stand in reply to JMS/.MN, 01-21-2008 13:21:23
we made one with some i beam and a final drive off a jd chopper same as a combine. put a plate where the wheel went and mount to it. it works good you can put a good sized diesel on and turn it no problem
