Allis D-17 Carb Adjustment Screw
Smith1000
01-20-2008 11:04:51
third party image
Does anyone know where I can find a carb adjustment screw for a D17 Marevel Schebler carb? The tractor was non-running when I acquired it. Amongst other problems, it was missing the adjustment screw. I have a bolt in it currently with a grooved cut in it for fuel flow, but I would like to replace it with the right part. Thanks.
Jeff Z.
01-20-2008 19:24:01
 Re: Allis D-17 Carb Adjustment Screw in reply to Smith1000, 01-20-2008 11:04:51
If you would like some good info on these carburetors just drop me an email.
mlpankey
01-20-2008 15:18:58
the screw at the bottom is actually a needle to make the jet smaller . you can usually find one at youre local carb shop that will work or make youre on by sharpening a piece of tig rod and spot weldining it to a screw.
CENTAUR
01-20-2008 12:24:42
What is that screw on the top going down at about a 45? CENTAUR
Jeff Z.
01-20-2008 19:20:03
 Re: Allis D-17 Carb Adjustment Screw in reply to CENTAUR, 01-20-2008 12:24:42
That top needle valve is for low speed idle adjustment.
Jeff Z.
01-20-2008 12:18:45
Try giving {The Carburetor Shop} and {Robert"s Carburetors} a call. Search both on Google
Jeff Z.
01-20-2008 12:26:37
 Re: Allis D-17 Carb Adjustment Screw in reply to Jeff Z., 01-20-2008 12:18:45
You can also send an email to this site for part suppliers. They won't sell parts to you but they will give you supplier names.
http://www.mainelymagnetos.com/carbshop.html
Smith1000
01-21-2008 04:45:34
 Re: Allis D-17 Carb Adjustment Screw in reply to Jeff Z., 01-20-2008 12:26:37
Thanks for all of the great feedback. I will check out these sources for an adjustment screw. I am not exactly sure of the technical name for the piece. Thanks.
