WD pushing snow , hyd vibration
VA Gasman
01-19-2008 05:48:44
Thursday I was pushing snow with WD. It has a 8' moldboard made from a section of 24" gas pipe. and is mounted on front with push arms engineered under from under the rear axle area. It will lift about 4' high to push up drifted snow. I noticed that this year there's a vibration at full throttle when you engage Hydraulic lift. Seems to be worse the colder it is. Is this a concern?
K.Farmer
01-21-2008 15:04:19
 Re: WD pushing snow , hyd vibration in reply to VA Gasman, 01-19-2008 05:48:44
probably because the oil is so thick, that the pump has a hard time staying primed. or its low on oil.
alliswd45
01-19-2008 13:54:09
shouldn't be a problem
