D14 Starter
Darek
01-19-2008 05:17:28
I have purchased a 59 D14 that came with a Delco starter 1107474. The starter does not work and replaced with rebuilt Delco to match the numbers, but definately not correct. Does anyone know what the original starter #s where? Tractor has been converted to 12v.
much thanks
DP
JimNWMich
01-22-2008 06:14:14
 Re: D14 Starter in reply to Darek, 01-19-2008 05:17:28
My 1957 D-14 came as 6 volt, has been converted to 12 volt with alternator. I still use the 6 volt starter because I was told the nose cone for the 12 volt is not the same. You may need to check with an AGCO dealer (or someone else with the correct parts book for your year and serial number) to get the correct starter. HTH Jim
Jeff Z.
01-19-2008 10:22:01
There is a D15 starter on ebay. Should be the same as the D14.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=200192772578&ssPageName=STRK:MEWA:IT&ih=010
