allis chalmers remote spool valves
Charles Smith
01-18-2008 13:15:24
I have 3 AC tractors, 170 gas, 185 diesel, and 190XT diesel. All three have weak remote hydraulic spool valves. I assume that they need to be rebuilt. Where can I get a repair manual and parts to rebuild these units? Note: I think that all three tractors have the same valves, and the three point lift arms work fine on all of them.
Joe(TX)
01-21-2008 09:19:44
 Re: allis chalmers remote spool valves in reply to Charles Smith, 01-18-2008 13:15:24
I would doubt that the spool valve is the problem. One of the spools operates the 3 pt.
What kind of a problem are you having?
Have you checked your quick disconnects?
Charles Smith
01-21-2008 13:51:45
 Re: allis chalmers remote spool valves in reply to Joe(TX), 01-21-2008 09:19:44
I have changed the couplers on one of the tractors and have had no effect on the system. Both remote spools are very weak. They kick out very easily when operating remote cylinders. I have to feather the controls to produce any lifting capability. Until the oil is warm, my front end loader will not work at all. I think that the pump is ok because the 3-point arms work correctly.
Joe(TX)
01-21-2008 09:19:30
