Allis Chalmer D14-Jumping out of 3rd
travisa
01-18-2008 08:25:22
Folks, I've got an Allis D14 that wants to jump out of 3rd. How does one fix this problem, and is it worth it? Thanks
John (MO)
01-18-2008 09:06:34
 Re: Allis Chalmer D14-Jumping out of 3rd in reply to travisa, 01-18-2008 08:25:22
It can be fixed, but the cost depends on what is causing the problem. Worn forks can be fixed a lot easier and cheaper than worn gears can.
acdave
01-18-2008 08:57:16
sometimes if you know someone who knows how to grind the shifter forks they can fix this i have done 2 a 170 and a d 15 and it has worked for several years where are u located we have an agco dealer here who has a mechanic that has done it for me David
travisa
01-18-2008 09:06:45
 Re: Allis Chalmer D14-Jumping out of 3rd in reply to acdave, 01-18-2008 08:57:16
I'm located in Corsicana Texas
1755
01-18-2008 19:05:18
 Re: Allis Chalmer D14-Jumping out of 3rd in reply to travisa, 01-18-2008 09:06:45
Our CA started that with second gear I took the side cover off to see if I could figur out what the problem was and the shift forks had whear on them welded them up with a wire feed welder and filed them back down and put it back I had to weld up both sides on the one fork and one side on the other fork I think 1, 2, and 3rd had whear on them but 2nd was the worst and there was not alot of whear on there but I welded it up and hoped for the best and that was 3 or 4 years ago have not had problems of corse I dont know how long it will last but as long as it dont where out the calers in the trans it can be welded up agin
Ohio D14
01-20-2008 18:04:54
 Re: Allis Chalmer D14-Jumping out of 3rd in reply to 1755, 01-18-2008 19:05:18
Does one have to split the tractor for this, or can it be done without removing the transmission? I am looking at possibly putting in a new clutch for a D14, and wonder if that would be a good time to look at the transmission and power director to make sure they are in good shape, but would rather not have to split the tractor.
1755
01-21-2008 07:09:46
 Re: Allis Chalmer D14-Jumping out of 3rd in reply to Ohio D14, 01-20-2008 18:04:54
I dont Know about A D14 but finding out if you can take a cover off the trans and look at the shift forks would be a good idia becous if you cant get at it fron the out side you will probly have to split the tractor to get it apart to fix the CA has a side cover that has the shift forks in it and it is all right there to look at but I have not worked on any other AC than a CA
