Allis-chalmers Buda engines
Phillip Simms
01-16-2008 18:54:14
Were Buda engines used in the HD 19, 20 and 21 series dozers? If so, what is the description of the engines used in each series?
loveshisallis
01-24-2008 10:19:52
 Re: Allis-chalmers Buda engines in reply to Phillip Simms, 01-16-2008 18:54:14
third party image
Here's one I took last year in Pontiac,Il.
steve(ill)
01-17-2008 18:21:23
the 844 used in the 21C dozer was called a 21000 series. it was turbocharged. if you added an aftercooler we called it a 25000 series. that was used in a few scrapers and the 945B wheel loaders from Deerfield. The 844 was a very common motor that went from about 175 HP up to 400 HP over the years with updates and turbo, aftercooler, etc.
Tramway Guy
01-17-2008 10:30:28
HD-16 used the Non-turbo version of the 844 CID Buda Engine, while the HD21 used the Turbo version, at least in the HD21A series.
I had the pleasure of operating a HD21A one summer. It was some machine! And just about the easiest starting diesel I've ever seen.
greygoat
01-17-2008 09:49:50
The Book "Allis Chalmers Construction Equipment"
available at Barnes & Noble-others, or your
library, lists the relationship. Allis used
Detroit Diesels until GM bought Terex and started
to compete in construction equipment. Allis, not
wanting to purchase engines from a competor, then
bought Buda, in 1953, after that, all allis diesels were Buda. 844 was Buda. They made up to a 1200 cubic inch V12.
Joe(TX)
01-18-2008 05:22:00
 Re: Allis-chalmers Buda engines in reply to greygoat, 01-17-2008 09:49:50
FYI
The Book "Allis Chalmers Construction Equipment" is no longer available, it is out of print.
hectorgemme
01-17-2008 02:48:07
the hd21 use BUDA ALLIS
John (C-IL)
01-16-2008 20:31:13
THe HD19 used a General Motors 6 cylinder diesel. 426 cubic inches rated at 110.64 HP.
The HD20 used a General Motors 6 cylinder diesel. 660 cubic inches rated at 116.69 HP
The HD21 used an Allis Chalmers 6 cylinder diesel (4 stroke) 844 cubic inches rated at 135 to 147 hp depending on the model.
