ID number on engine block. WD
Dennis Rimert
01-15-2008 14:20:37
I have serial no. wd320467pa on my engine block and can not find year and what tractor it is out of. I think its a wd or wc. Thank you for the help.
Brian G. NY
01-16-2008 16:11:12
 Re: ID number on engine block. WD in reply to Dennis Rimert, 01-15-2008 14:20:37
Dennis, I think you either have one too many digits or an incorrect digit in your number.
With a WD prefix and a PA (high compression) suffix, it has to be a WD engine. However, the last WD engine serial number was 146606.
Maybe you could look at it again for us?
Dennis Rimert
01-16-2008 19:07:10
 Re: ID number on engine block. WD in reply to Brian G. NY, 01-16-2008 16:11:12
Thanks for the help. Motor is going in a wd45.
Brian G. NY
01-16-2008 16:20:07
Dennis, Ignore what I said; John is right, it is probably a 1952. I was mixing "tractor" numbers with engine numbers. Sorry 'bout that!!
John (C-IL)
01-15-2008 17:13:36
Here is Brian Smith's list.
1948 7 - 9249 200775 - 210718 1949 9250 - 35444 210719 - 238901 1950 35445 - 72327 238902 - 278584 1951 72328 - 105181 278585 - 313931 1952 105182 - 126931 313932 - 337332 1952 127007 - 131242 337333 - 341970 1953 131243 - 146606 341971 - 358500
Looks like your engine would be from a 1952
Dennis Rimert
01-16-2008 19:08:58
 Re: ID number on engine block. WD in reply to John (C-IL), 01-15-2008 17:13:36
Thanks for the help John. I could not find a list like this one.
John (C-IL)
01-15-2008 18:17:27
That didn't turn out too well. The first number is the date, the next set is the tractor serial numbers and the next set is the corresponding engine serial numbers.
alliswd45
01-15-2008 16:57:35
should be out of a WD, because i have a WD-45, serial number starts with 45, for WD it would start with WD and so on so forth. dont't know the years, so i can't help you there.
