exhaust nipple size on WD
VA Gasman
01-15-2008 04:06:13
I have a 1950 WD that has a thin wall tubing nipple installed in the exhaust outlet of manifold. The previous owner had only a straight pipe on this. It also has a lock screw in the outlet of the manifold to hold in place . I have installed muffler to quiet it down. The nipple does not set good now. Did this have pipe thread to hold the muffler nipple? It looks the same diameter as 1 1/4" NPT pipe threads.
R Aiken
01-15-2008 14:24:52
 Re: exhaust nipple size on WD in reply to VA Gasman, 01-15-2008 04:06:13
I just went out to the barn and masured one of those new Stanley mufflers, 1 3/4". I put one on my WD last summer , it is a tight fit. If you have a threaded pipe in your manifold, it is a D17 or E Gleaner. Richard
CWL
01-15-2008 04:46:24
The manifold on my WD is not threaded. It just has a set screw in the side of it.
Jack a
01-16-2008 04:00:22
 Re: exhaust nipple size on WD in reply to CWL, 01-15-2008 04:46:24
A nelson muffler wont be a lose fit. Get rid of the nipple. The shell on the Nelson muffler comes all the way down to the "setscrew". You install the bolts (should be two) through the shell into the manifold. Makes it solid and rain won't get in. Nelson cost more money though.
