D17/Gleaner E
alliswd45
01-14-2008 17:28:07
What is the difference between a Gleaner E engine and a D17 engine.
Jack a
01-16-2008 04:01:50
 Re: D17/Gleaner E in reply to alliswd45, 01-14-2008 17:28:07
Also the E has a little more power because of a little higher compression.
gary tomaszewski
01-15-2008 09:16:22
The combine engine is governed for high idle(working speed), very little action at anything less than full throttle.
JMS/.MN
01-14-2008 21:58:58
Engine is basically the same- but combine engine has a fuel pump on the side---D17 is a gravity flow from the fuel tank. If you put it into a tractor- need to remove the fuel pump and block the mounting. Might also be a governor issue- lots of info in archives.
