WD grader blade - need ideas!
Rock_Picker(MO)
01-12-2008 20:24:54
I"m looking for a way to modify a rear mount 3 point blade (existing) to get a better job of grading my gravel driveway (driveway is hilly and about 500 ft long). Thought about putting wheels on the blade. Also thought about mounting the blade under the belly of the tractor (probably using a front cultivator setup for support). I"m hoping some person(s) on this forum has done this and has pictures or links you are willing to share. Looking forward to hearing from you..... ...thanks..... RP
SP Indiana
01-13-2008 17:30:55
 Re: WD grader blade - need ideas! in reply to Rock_Picker(MO), 01-12-2008 20:24:54
i have a old IH blade behind my WD45 i got a set of snow plow skids that are adj. works great
Garry from SD
01-13-2008 07:07:17
A freinds father-in-law had a blade made for his WD45 that was mounted under the tractor. He had to notch areas out for the tires so they wouldn't rub. The up and down pressure came from using the mounted loader. The blade could be attached to the loader arms when he wanted to grade then he detached it from the loader and attached it up to the frame when he didn't need it. It always stayed on the tractor. I believe he used knuckles to hold it up and attach to the loader. It really worked good.
Old, just out of curiosity, how much time do you spend grading your mile?
old
01-13-2008 08:12:15
 Re: WD grader blade - need ideas! in reply to Garry from SD, 01-13-2008 07:07:17
When I do mine and my moms drive it takes me about one to two hours depending on how bad it is. But I have been running that machine for so many years I have figured out just how to do it and now days I only have to grade the drive 3 or 4 times a year, unless we get a lot of rain then some times more. But my drive way is also well graveled at I'm guessing 2000 plus loads of gravel over the 28 years I have lived here
Garry from SD
01-14-2008 14:42:03
 Re: WD grader blade - need ideas! in reply to old, 01-13-2008 08:12:15
Sounds like you spend more on your drive then most counties spend on the roads. It'd be nice if the counties spdent a little more time in maintaining, been on a few that shook my truck apart.
NE IA
01-12-2008 23:56:37
I have a W Speed Patrol, and like Old said you need extra arms. I did see one once that they cut the front end off and put a trailer ball hitch on it. They then ran hoses back to the W and put cylinders on instead of the mechanical wheels for lifting, They could control the up and down extreems with the pulling tractor's 3 point hitch, I'm thinking why not mount your blade under a junk tractor. You could use a snap coupler set up for your AC for the pulling tractor.
Being able to crown a road is priceless.
Another thought is to bolt on the rear wheels from a old PTO driven hay rake to a rear blade. So you have a arch, and thus using the rear rake wheels for guage wheels probably four to five feet behind the cutting edge. Perhaps even being able to tilt the blade as you would have done on the hay rake. I have never done this, but have thought about it numerous times.
Our area still has a few horse drawn graders, some have had the front wheels taken off and a tractor hitch put on instead. Again the 3 point of the pulling tractor controls the cutting depth. The trouble in our area these things have went up in value pretty bad the last ten years.
Rock_Picker(MO)
01-13-2008 19:21:36
 Re: WD grader blade - need ideas! in reply to NE IA, 01-12-2008 23:56:37
I like your idea about using an old hay rake. Will think about it some and visit a few auctions to look for a frame. I'm still favoring some kind of a wheel support system for the blade..... .seems like it would have better control and not go up or down depending on what the front of the tractor does....tx.....RP
william myers
01-12-2008 22:56:49
I have a 7` foot grader box on my wd, it works great grading my road, like Old, its a better road than the countys.
old
01-12-2008 20:54:39
Rock, I know I have probably asked this before but since I'm on here so much I forget some times. Where are you in Missouri?? Any how a blade mounted under the belly does the best job of road work and if you look in my web site you will see how Allis made a set up for the WC but they did a lot to them to have it work well. I have a mile long drive plus my moms 1/2 mile I keep up and most of the time its better then the country roads are. My WC Speed patrol does a good job but takes 8 arms to work it
Rock_Picker(MO)
01-14-2008 15:12:11
 Re: WD grader blade - need ideas! in reply to old, 01-12-2008 20:54:39
Old: I sent you an email regarding my location a couple of days ago..... .....did you get it?..... ...RP
old
01-14-2008 15:26:08
 Re: WD grader blade - need ideas! in reply to Rock_Picker(MO), 01-14-2008 15:12:11
I don't think I got it. I do get a lot of emails but if you sent me one I don't remember it and most of the time I reply to the ones I get
