Oil pan
TroyR
01-11-2008 13:57:07
'39 B I was wondering if somebody could tell me what the oil pan bolts should be torqued to Troy in Wa.
Dick L
01-11-2008 17:32:29
 Re: Oil pan in reply to TroyR, 01-11-2008 13:57:07
Just snug enough to flaten the lock washer. If you tighten a pan gasket to tight it will cause it to leak between the bolts. You want to make sure the lock washer will work. Also keep all the bolts the same which means you go back over them several times making them just a little tighter each time. That would be a stamped pan. The cast pan will not act the same way.
alliswd45
01-11-2008 14:16:40
I don"t know much about a B, but on my WD-45, didn"t say any thing about torqing, prbably don"t need to be, just tighten them evenly.
