Wc belt ?
slowsmoke
01-09-2008 07:44:57
Getting ready to put a distributer and alternator on a WC. Anyone got the part # of the alternator belt(longer than just water pump belt)? thanks much!!
stu (ON)
01-09-2008 09:26:56
 Re: Wc belt ? in reply to slowsmoke, 01-09-2008 07:44:57
Have been using a Dayco DA 17460 successfully on the WD for the last year. 46" long by 5/8" wide, if I recall correctly. It's all the width that the alternator pulley can take, and is just wide enough for the sheave on the water pump.
Your results might vary.
slowsmoke
01-11-2008 02:16:06
 Re: Wc belt ? in reply to stu (ON), 01-09-2008 09:26:56
Thanks!!
old
01-09-2008 09:03:03
Last one I did which was on a WD I used the same belt as I did for the generator. I did also take the pulley off the genny and put it on the alternator and so far it has worked just fine and that was 2 or 3 years ago that I did that
slowsmoke
01-09-2008 09:16:45
 Re: Wc belt ? in reply to old, 01-09-2008 09:03:03
Old This WC had no alternator or generator. hand start and Mag. Thanks
massey333
01-09-2008 12:45:21
 Re: Wc belt ? in reply to slowsmoke, 01-09-2008 09:16:45
slowsmoke,I knew your wife was going to get tired starting that thing for you.
