WC E-Gleaner
n-1
01-07-2008 16:08:09
I have a 1942 WC Allis. I put an E-Gleaner combine motor in it. The govenor will not work at low RMP's, but works well at high RMP's. Is there a difference between tractor governors and combine govenors? How can I fix my problem? Does anyone have a trick to fix this without changing out the govenor.
slowsmoke
01-09-2008 07:35:43
 Re: WC E-Gleaner in reply to n-1, 01-07-2008 16:08:09
Combine has a min/max governor, not a full range. you need the tractor style front cover on the motor. Good luck!
Jack a
01-08-2008 03:26:36
Internal spring is different and hooks to a different place. Change the spring and readjust linkage as according to D17 manual and it will work great.
alliswd45
01-07-2008 16:46:00
It might be in the throttle linkage.
