Back at it again today. I have gotten to the point of being done messing around and want to take the mag off the tractor and would like to "set it up" at #1 TDC. THE SAD THING is that I've done this before, but didn't have this problem; 1.) I have brought #1 cylinder to the top 10 times and the metal gear on the mag with the little dimple consistantly ends up at bout the 9 o'clock position. I thought that it should be at about the 12 o'clock position. What is going on, or what am I missing? HELP! 2.) When this thing died in the driveway, it just died! No sputtering, nothing,..... ....just like you grounded the mag out. 3.) What are some of the basic things I can check for continuity? I am assuming that something is "shorted out". I have been checking out things but I have a somewhat limited knowledge of what should show continuity, and what should be isolated from the machine. 4.) I did remove the mag grounding lug wire, and ran a wire through the hole out to my grounding switch, so as to aviod the "potential" of the grounding lug being the culprit. Any help is greatly appreciated as we're real warm today, the driveway is near plugged with drifted snow,..... ..... 18* is back on the way and all this will be frozen, as well, ain't making any wood! Thanks! Pete
