D17iv specs
flamegunrh
01-06-2008 06:04:00
OK...where is the specs,for instance main journal diameter,rod length centerline to centerline,deck heighth, you knowthe machine shop stuff,is that in the shop manual?Any thoughts about the pullers? Do they pull with unstroked engines...modified oem class?I am struggling with this hydraulic problem itseems to be a matter of adding a resevoir(maybe in the arm of the loader) but don't over tax the stock tractor system 'cause the over heated hydraulic oil will cause the 3pt and draft control to get quirky.Any advice or insight or part numbers for tried and true systems or manuals will be deeply appreciated.
JMS/.MN
01-06-2008 12:08:46
 Re: D17iv specs in reply to flamegunrh, 01-06-2008 06:04:00
In the I&T series, it is AC-17. Covers a bunch of D-series tractors.
