Question on model B headwork
loveshisallis
01-05-2008 16:39:03
I am going to redo the head on my model B. I would appreciat3e any and all help I could get with pointers on how to lap/graind the valves, inserting valve guides, etc.
thanks in advance
DS Mi
01-06-2008 05:46:28
 Re: Question on model B headwork in reply to loveshisallis, 01-05-2008 16:39:03
I have to jump back in here.I agree with that if valves and seat's are to bad you need to take to the pro's.I'm talking about a slight cleaning or polishing. A head is not worth damaging.
Dick L
01-06-2008 07:27:28
 Re: Question on model B headwork in reply to DS Mi, 01-06-2008 05:46:28
Like I said in a post way below,the word (rebuild) has many meanings to different people. Making something work for a while longer with laping compound and wire brushes is just fine and it could mean the differene between being able to use a tractor or having the tractor sit around until a person has the 300 bucks or so to get it rebuilt. Sometimes that takes years for that to happen.
Today a good rebuild of a head for this tractor will probly last any one of us our lifetime.
Jeff Z.
01-05-2008 21:07:47
I have no problem with someone who likes to do the job himself and to learn.
When it comes to valves I leave that to the experts. You can do valve jobs every day and still learn something new on every job.
I would take the head to a engine machine shop.
Dick L
01-05-2008 19:38:50
I was taught to grind valves and seats 50 some years ago. If you have no one to look over your shoulder on the first cylinder head you rebuild and think with conversation you will come out with a good job I would suggest you might just be good enough to do your own appendectomy.
There are conditions that you have to observe with a total understanding of how every part works and why. Do you know how deep the seat are in the head or how deep they were in the beginning. Do you understand when a seat can no longer be re ground and must be milled out and a new seat installed? I am all for every one that wants to learn to have that opportunity but I hate to see you spend all the time trying to rebuild your head from opinions of people thru an open board that can not be by your side. Some Pictures Of What Is Used
third party image
third party image
third party image
third party image
third party image
BushogPapa
01-06-2008 20:11:17
 Re: Question on model B headwork in reply to Dick L, 01-05-2008 19:38:50
Hey Dick, do ya know of any source for stones for my old "Blue Point"/Snapon seat grinder..?? 1 1/4" to 2 1/2" would do...!! Seems the Big ones keep getting Smaller all the time..! Nice pics...I was looking to see some finished pics of your Valves..!! I dunno how to post any pics from my PC, or I would..! Ron.
old
01-05-2008 18:06:25
If your going to work on the top of the engine your better off if you also work on the bottom of it. Doing what you plan to do will increase compression on top and if so then because of old parts down below you can/will blow the bottom out. BTDT decades ago and learned if you fix the top you better fix the bottom of you will end up doing it any how and that will then cost you a lot more $$$. Now days when some one tells me they did a valve job on there engine and tell me it runs real good I tell them just wait 6 months and the bottom will fall out and every one has later come back and told me hey you where right
DS Mi
01-05-2008 17:33:05
Valve keepers are the split kind. they are easy.Just take one apart with spring depresser and it will become obvious.The valves will then fit into a cordless drill, and use compound and turn.That is if your seats arn't bad. Not a bad job I use small baggies for each valve. Don't mix them up.I keep storage bags of all sizes. DS
flamegunrh
01-05-2008 18:53:11
 Re: Question on model B headwork in reply to DS Mi, 01-05-2008 17:33:05
Iagree with"old" itjust don'tpay to do the top without looking that bottom over close.Withthat being said the cordlesss advice was good too CLEAN everything there are few substances more abrasive than lapping compound....There is also a technique called slapping, which is what you do,back thevalve off the seat a inch and slap the face firmly pull it out and you should see a light line ohh about 1/16th from the edge of the seat angle of the valve.or halfway across that angle this slapping isin addition to not instead of normal lapping procedures
