Re: Re: Re: Cub steering
Posted by George Willer on January 18, 2001 at 07:12:11 from (205.133.30.86):
In Reply to: Re: Re: Cub steering posted by David A on January 18, 2001 at 06:08:08:
I don't know if the A is the same as the Cub. I am sure neither has provision for adjusting the spacing of the gears, only shaft end play. The vertical shaft in a Cub is sort of adjustable for end play. The bottom of the worm gear rides on a bronze surface. The top of the steering lever rides on another surface that is on the bottom of the steering box. The distance these two are apart determines end play in the vertical shaft. There is a nut on the bottom of the shaft that will pull the lever up toward the box(while the clamp bolt is loose). I would pull it up as much as possible and then back off a little to eliminate binding. Then make sure the clamp bolt for the lever is TIGHT! Of course, this will be useful only if the A steering box is similar.
Post A Followup
: Re: Re: Re: Re: Cub steering
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
