The hand crank ratchet is SUPPOSED to retract into the bolster far enough so it is FLUSH and will not interfere. Use copious amounts of penetrating oil, a hammer, and a pry bar, and a whole lot of patience,and see if you can get that thing to move
The alternator belt is supposed to fit over a pulley on the water pump. You will need to remove the fan belt first, and then you can remove the alternator belt. Both of those belts will need to come off OVER the fan. It CAN be done.
You've already got extra pulleys on the crankshaft, why not use one of them for the power steering pump?
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our
... [Read Article]
