Posted by Janicholson on April 13, 2014 at 06:28:11 from (74.60.94.18):
In Reply to: farmall 200 posted by dewy on April 13, 2014 at 05:46:06:
The cylinder that leaks down is either leaking Hydraulic oil past the cylinder seals, or the valve controlling it is leaking back past its seals. I assume the rear cylinder is connected to the hydraulics on both top and bottom of the cyl. If it was connected with one hose it would be leaking fluid out the top if it was the piston leaking. If it is one hose, and if it is not leaking it is the valve. With no malace in my heart, I ask you again to use a subject line that mentions the problem. Hydraulic leak down - Farmall 200 As an example. It prevents people from looking at the post unnecessarily to figure out if they know what the answer is. It is a courtesy to the forum. (Not a Flame!!) Jim
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our
... [Read Article]
