Posted by Seth Boyer on January 31, 2014 at 17:15:26 from (69.29.213.21):
Well its been well over a year since I"ve posted anything on the forum and about as long since I"ve been working on my F-12. Wanted to share something I discovered while tearing apart multiple F-12 and F-14 carbs.
I have two factory high compression gas carbs #29953-DC and two low compression kerosene special #29954-DB. The two main differences I found are in the Venturi and the Adjusting Screw Seat for the Fuel Adjusting Screw.
I can take pictures and measurements of the Venturi if anyone would like. The opening of the gas venturi is a lot larger than the kerosene one. It would be easy to drill out a kerosene one to the same factory specs as a gas one.
The Adjusting Screw Seat on both carbs have two holes. One being straight through the end. The other being through the side just above the threads. On the high compression gas carb both holes are drilled with a #49/.073" bit. On the low compression kerosene carb the holes are different sizes. The one out the end is drilled with a #56/.046" bit and the side hole is a #29/.136" bit.
Hope someone finds this info useful and may want to experiment with modifying their carb to see if any differences in power are found
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
