Posted by Bob M on January 28, 2014 at 09:14:45 from (69.207.86.40):
In Reply to: Super M LP posted by 62c100 on January 28, 2014 at 08:50:00:
I'm unfamiliar with the SM LP system. I however regularly run a Minnie-Mo G-LPG in winter weather. Gotta think the starting procedure is the same for your tractor:
1 - Open the vapor valve
2 - Set governor handle to about 1/4
3 - Turn on ignition, pull the enrichment ("choke") knob and hit the starter
4 - Soon as the engine fires push the enrichment knob back in
5 - Let the engine run a few minutes to warm the vaporizer. Then close the vapor valve and open the liquid valve. You are now good to go.
To shut down, close the liquid valve and let the engine run until it quits. Don't forget to turn off the ignition after the engine stops(!)
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
