Re: Broken bolt extractor in engine block
Posted by mkirsch on January 18, 2014 at 16:22:11 from (67.253.175.33):
At Lowe's, in the drill section of the tool department, they have various small-diameter DIAMOND hole saws.
Get the diamond hole saw the same size as the nominal bolt size for that hole. If it's a 5/16" bolt, get the 5/16" hole saw, for example.
The hole guides the hole saw, and the hole saw drills out around the easy-out.
You'll have to thread the hole for the next size larger, but at least you'll have a bolt in the hole, and the easy-out is GONE!
Works slicker 'n snot.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
