Disc Brake repair on SH
Posted by VA Gasman on October 04, 2013 at 17:10:32 from (75.192.204.112):
I was told you could repair worn brake housing tolerance on disc brake assemblies by replacing the steel balls in the actuator plates. I don't think I have seen that discussed before. Where would you find larger steel balls??
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
